Hello,
First let me say, I'm an Autodesk idiot. So if you respond, you need to speak really slowly if you catch my drift.
I am using AutoCAD Civil 3D 2009.
I have a Ribbon, and I managed to add an "Object Snap" Ribbon Panel to my Ribbon tab "Home"
I even managed to creat this little beauty for a little icon of Mid-point between two points.
(Feel Free to Steal it)
But For the Life of me, I can't get any Icons to show up in my actual ribbon. here is the procedure I am using to try to get those to show.
Open CUI
Customize Tab, pull down menu to "acad.cui"
Expand the Ribbon Panels
Expand the Panel in Question "Object Snaps"
Highlight a command with no icon (One being end point snap)
When highlighted the Panel Preview show a Iconless ribbon panel
however the "button Image" shows the correct Icon.
I then scroll through all the Icons inside the Button Image portion of the screen and Select the correct image. Now the Panel Preview shows correctly.
However when I hit the apply or Ok button nothing changes on my actual Ribbon Panel, and I still have an Iconless Panel.
When I reopen my CUI and go back to the "Object Snaps" Panel, it once agains show Iconless in the Panel Preview.
Any Ideas on how to fix this? I've had the two CAD guru's at my office look at it, and they are puzzled as well.
Thanks for your time!
