Thread: Frit pattern curtain wall panel
    2006-01
    Toronto
    27
    Default Frit pattern curtain wall panel
    Hi everyone,
    I'm trying to import CAD files into Revit curtain wall panel families. Reason for this is to develop a frit pattern on unique panels. The CAD files include hundreds of points which have a size of 10mm. These settings were specified in the CAD file (PDMODE & PDSIZE).
    Problem is that importing the CAD file into the family it causes the points to resemble actual points rather than circles.
    Is there a way to allow Revit to understand these points as circles? Or a way to convert the points in the CAD file to true circles?
    2006-06
    Toronto, ON
    2,386
    Default Re: Frit pattern curtain wall panel
    Are you trying to import the CAD files to actually model the frit pattern circles? If yes, wouldn't be better to create a new model pattern (maybe using the Hatchkit tool) with the pattern you want and then just use it with your panel?
    Andre Carvalho
    2006-01
    Toronto
    27
    Smile Re: Frit pattern curtain wall panel
    I wasn't going to go that direction although I have given it thought. I had come across hatchkit before but I will see if it is useful in this case, in theory it sounds like the most ideal choice. I'll let you know how it works out.
  1. 2013: Adaptive Curtain Panel pattern problem? Curtain Panel pattern overlaps on certain patterns
    By robertlevy493178 in forum Revit Architecture - Families
    Last Post: 2012-08-31, 04:56 PM
  2. normal vs. pattern based curtain wall panel
    By Ning Zhou in forum Revit Architecture - Families
    Last Post: 2010-09-13, 01:41 PM
  3. Curtain panel by pattern??
    By agustnj.187972 in forum Revit Architecture - General
    Last Post: 2010-01-19, 02:10 PM
  4. Better access to curtain wall panel widths in panel families
    Last Post: 2009-11-03, 03:22 PM
  5. Curtain Panel By Pattern Families
    By hand471037 in forum Revit Architecture - Families
    Last Post: 2009-07-07, 09:50 PM
