Results 1 to 1 of 1
Thread: Curtain Walls: Scheduling Mess ?
    2008-10
    10
    Angry Curtain Walls: Scheduling Mess ?
    Ok, single excersice. Draw two curtain walls and try to obtain an schedule of the panels needed for each wall.
    In the attached revit file i haven't solved and found some problems:
    1. There is no way to obtain in the "curtain panels" schedule a FIELD wich indicates some reference to the wall that the panel belongs.
    2. In the "walls schedule" there is no way to FILTER the curtain walls from the generic walls becouse the Family / Type filter is not enabled or not listed.
    The only way i found to set an ID to a wall is with the "mark" property. But using the "mark" property panel by panel within a curtain wall is like ... an english word that i would not put in this forum.
    Any idea ? ...
  1. Replies: 4
    Last Post: 2008-12-18, 08:03 PM
  2. Scheduling curtain walls, railings or studs
    By Steve_Bennett in forum Style Management
    Last Post: 2008-11-06, 02:07 PM
  3. Scheduling Comments & Curtain Walls
    By d.stairmand in forum Revit Architecture - General
    Last Post: 2007-11-13, 04:09 AM
  4. Scheduling doors in curtain walls
    By tim.101799 in forum Revit Architecture - General
    Last Post: 2007-08-06, 02:19 PM
  5. Scheduling Curtain Walls
    By hweiler in forum Revit Architecture - General
    Last Post: 2007-04-03, 07:53 PM
