Thread: Plot Multiple Layout tabs
    I could stop if I wanted to roy.70844's Avatar
    2004-06
    South Wales UK
    276
    Question Plot Multiple Layout tabs
    Hello there,
    In Autocad 2004 I could right click on any layout tab, choose select all layouts
    Right click on a tab again and choose plot. This would allow me to print all my layouts at once (to 1 plot device which is no problem as I only use 1).
    When I do this in 2005 the plot option is grayed out. Has this function been dropped?
    Regards,
    Roy
    150700
    3,421
    Default Re: Plot Multiple Layout tabs
    Try selecting publish all layouts. This will take you to the replacement for batch plot - publish. The dialog box will open up, all your layout will be there, you can select your page setup for all layouts - you can select all of them, and right click to change the page setup all at once - and then hit publish
    HTH
    Member matt.bellenoit's Avatar
    2002-03
    Northampton
    32
    The Publish command works, but for me is a LOT slower than the old select all the tabs and hit plot...
    2004-06
    South Wales UK
    276
    Thanks for the replies.
    I got the publish to work, but it did not seem to keep the .CTB associated with each layout.
    Am I missing something. Could it be something to do with the page setup bit?
    Roy
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    1,901
    Are you using named page setups in each layout?
    I didn't have time to test it but it would seem logical that Acad would use the CTB in a named page setup.
    Jeff Paulsen
  1. FIELDS IN MULTIPLE LAYOUT TABS?
    By athel6 in forum AutoCAD General
    Last Post: 2010-07-31, 12:15 AM
  2. Rename Layout tabs on multiple .dwg
    By Dave Lewis in forum AutoCAD General
    Last Post: 2008-03-19, 07:40 PM
  3. LDT 2006 - Plot multiple layout tabs with PUBLISH
    By johnvicki in forum Land Desktop - General
    Last Post: 2007-04-25, 03:58 PM
  4. Plot Multiple Layout Tabs
    By Rayllen in forum Land Desktop - General
    Last Post: 2005-11-11, 02:07 PM
