Results 1 to 7 of 7
Thread: Grayscale in surface patterns and filled regions
    2008-04
    67
    Default Grayscale in surface patterns and filled regions
    I probably should know this by now, but I still struggle with getting values into lines in elevations, especially with fill patterns. (See attached) How can I get these lines to gray down?
    2001-07
    Phoenix, AZ
    1,003
    Default Re: Grayscale in surface patterns and filled regions
    Change the Fill Projection line color/weight in Visibility Graphics in the Wall Catergory to affect the entire view. You can also set this up to affect walls globally in Object Styles.
    2008-04
    67
    Cool Re: Grayscale in surface patterns and filled regions
    OK. That helps with the walls. What about filled regions/patterns?
    2006-06
    Toronto, ON
    2,386
    Quote Originally Posted by AUGI Strangelove View Post
    You can select any element you want in elevation > right click > Override graphics in view > By element > change the pattern color for cut or projection to be the color you want.
    Andre Carvalho
    2008-04
    67
    Thanks. I can get the color changed easily enough, but it still prints black, unless I change the whole filled region to halftone. If I do that, it also makes the outside lines halftone, which I'd like to have display as black, and fat for the ground line.
    2001-07
    Phoenix, AZ
    1,003
    You should be getting a WYSIWYG in your prints. If not then it's your printer settings.
    2008-04
    67
    Thumbs up Re: Grayscale in surface patterns and filled regions
    I think that's the ticket. Thanks.
  1. Filled Regions with Model type Patterns in Halftone
    By Brian Carino in forum Revit Architecture - General
    Last Post: 2018-06-19, 04:29 AM
  2. 2015: Hatch Patterns or Filled Regions
    By cberteaux371801 in forum Revit Architecture - General
    Last Post: 2015-03-18, 04:53 PM
  3. 2012: Naming Filled Regions and Fill Patterns??
    By Bike-Ramrod in forum Revit Architecture - General
    Last Post: 2013-04-11, 03:32 PM
  4. material surface patterns on split regions walls won't update
    By davidthigpen in forum Revit Architecture - General
    Last Post: 2009-03-20, 02:08 PM
