Openwheeler
I’m working on using sheet set in our moving to Civil 3D, but need to get the basics down with sheet sets first.
I have made template files and have the .DWG files too.
1) made a sample project folder
2) blank project file (base.dwg)
3) newsheetset-which went though the wizard and created my sheets. I browsed to my template directory for the .dwg (help said you can use either one, is this true?), but only 3 of the 5 sheets had been made from the .dwg files in the template directory. Then if you get into the sheet, it changes my template file. Why is the source file being updated? Doesn’t the sheet set copy a version of the file? I not get this yet, so please help me with understanding the process of creating an independent sheet from a template file.
Thanks for putting me on the correct path. Hope this makes since.
