Thread: Viewport-type default
    2003-08
    37
    Default Viewport-type default
    Two questions:
    Say you have a list of viewport-types (with different title looks). 1. How do you define which one is the default when adding a view to a sheet? 2. How do you get rid of one that are not being used and you no longer want in the list? Note, I ran the purge unused, and it only came up with a couple of the types I wanted to purge. I have gone through all conceivable sheets and made sure no viewport was using the types I want to get rid of.
    Thank you
    2003-09
    1,907
    Default Re: Viewport-type default
    Second question first. Look under the family category of the project browser. You will find your types listed there. Select the ones to delete, right click and select delete.
    Running on memory, the last used viewport look (I assume you mean sheet layout type of look) is the becomes the default - could be wrong on that - don't remember...
    2004-12
    Brisbane, Australia
    69
    Quote Originally Posted by B. Strube
    I am interested if there is a solution to this question.
    Each time I drag a view onto a sheet it uses what seems to be a default view title. I then change it to the one that applies. I would like to be able to assign our Elevation view title so it is used when dragging an elevation view onto the sheet and so on...
    Thanks
    All AUGI, all the time janunson's Avatar
    2003-07
    Grand Rapids, MI
    650
    I did that by going into the template and renaming/modifying the one that was default to match the style i wanted by default... then deleting the other copy. Don't know why it defaults to one in particular but that seams to have worked.
    "It is a besetting vice of democracies to substitute public opinion for law." (James Fenimore Cooper)
    ""Interesting. No, wait...that other thing. Tedious."
    --Bender on Futurama
  1. Default Viewport
    By ralph.burkey in forum AutoCAD General
    Last Post: 2011-04-11, 01:48 PM
  2. Delete Viewport Type
    By KGC in forum Revit Architecture - General
    Last Post: 2011-03-08, 10:54 PM
  3. Viewport Title Default
    By Jrobker in forum Revit MEP - General
    Last Post: 2010-10-27, 11:45 PM
  4. Change the default viewport tag
    By jkipfer in forum Revit Architecture - Families
    Last Post: 2010-03-12, 10:52 PM
  5. Delete a Viewport Type
    By Gordon.Price in forum Revit - Platform
    Last Post: 2008-06-30, 05:58 PM
