can somebody explain to me how to make a custom surface pattern
I need a metric running bond that is 725mm x 425mm; I've tried editing an exisiting patterns and I lose the offset of the running bond.
thanks
thanks
I must have been calling it the wrong thing cause I couldn't find that earlier; I was looking in my hard copy of the User Guide and didn't find it in there either.
Thanks
is there a way to tell Revit it is a metric pattern or do I have to convert it to english units
do a search for creating autocad.pat files it is a "language" that revit adopted. Part of that language is the units, you can prefix the text in the .pat file with the units you want to use.
take a look at the revit-metric.pat file in your data directory.
Scott D. Brown, AIA
BECK
Hi Thomas
You have to define the units in the beginning of the pat file. this is how you define it.
;%UNITS=MM
Remember to define if you want it to be a Model Pattern, here is an example.
*Block 200x400, 190x390mm blocks running bond 10mm joint
;%TYPE=MODEL
0, 0, 0, 0, 200
90, 0, 0, 200, 200, 200, -200
thanks everybody; it took me a few trial and errors and I got it to work
tom
