I think I was able to get away with this problem by restoring my ARG files from my home computer.....I don't think that this is the solution...if anyone has a real solution please let me know. thanks!!
I find it hard to believe this thread has made it to two pages in length.
The OP's screenshot (really!? a .DOC!?) clearly shows that the menu bar is present within their workspace, and the OP makes it clear that there is only the Express menu being displayed.
The menubar does not float off screen (toolbars can, but not the menubar).
What the OP needs to do is open either restore a vanilla workspace, or use the ._cui command to open the CUI Editor and create/modify their current workspace by adding the desired menus to the menu bar which is already present.
Now, this may be an issue with the ACAD.cui not being loaded properly, etc. but the OP needs to report back to let us know how the simple steps pan out first.
Good luck!
Computer Specs:
Yep, there's only 3 ways this could happen:
IMO, the OP's got either 2 or 3 happening. Most probably 2 as RenderMan's stated. Anyway, this is a bit of an old thread isn't it? I wouldn't really like it when after 2 years someone finally gives me a workable answer
- The needed CUI file(s) are not loaded. E.g. the acad.cui in Vanilla, might be something else on Civil 3D. However, I don't think this is the OP's problem - since the toolbars show correctly (i.e. the CUI must have been loaded).
- The OP's workspace has the menu's turned off (all except Express). You can either swap to one of the default workspaces, or use the CUI command to turn the menus back on for your workspace.
- The CUI was recreated manually (maybe through transfer tab in CUI), but the menus weren't dragged across.
Computer Specs:
