Results 1 to 6 of 6
Thread: How to import excel table to autocad
    2008-09
    Default How to import excel table to autocad
    Hello
    How to import excel table to autocad2009?i know a software--the autoxlstable3.0 developed by www.cadaddon.com.
    is it ok?who were used to try it?
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,829
    Default Re: How to import excel table to autocad
    Read up on DataLinks.
    R. Robert Bell
    Design Technology Manager
    S P A R L I N G
    Opinions expressed are mine alone and do not reflect the views of Sparling.
    Member pouellet's Avatar
    2004-05
    St-Basile-le-Grand, Quebec, Canada
    8
    Thumbs up Re: How to import excel table to autocad
    Hi Robert,
    I'm using Autotable from Cadig.
    Take a look at http://cadig.com/products/
    Working really great and saved us lot of problems trying to use Autocad's Tables feature.
    There's a FREE 30-day trial version.
    PO
    Pascal Ouellet, Equipment designer
    Gala Systems Inc.
    Québec (Canada)
    Web : www.galasystems.com
    All AUGI, all the time Capt. Computer Crasher's Avatar
    2006-12
    South of North & East of West
    786
    Quote Originally Posted by mandy View Post
    Hello
    Mandy, third party software is not necessary. You can do as Robert suggests and use DATALINK command, which inserts the Excel sheet as a table in AutoCAD as you updated the Excel Sheet the AutoCAD table is updated also and vice versa. If you simply want to place the Excel data into AutoCAD with no link, then
    1) Highlight all cells in Excel that need to be in AutoCAD
    2) Right-click and choose copy
    3) open the AutoCAD drawing
    4) Click on the top EDIT menu then pick paste special
    5) make sure the paste button is highlighted
    6) in the window pick "AutoCAD entities"
    7) click at an insert point for table.
    you should have an editable AutoCAD table with the Excel Data.
    This works in 2007 & 2008 and should work for 2009 as well.
    2004-05
    8
    Capt. I'm still using Autocad 2007, is DATALINK a new std command in 2009, it's not working in my 2007 ?
    PO
    Gala Systems Inc.
    Québec (Canada)
    2006-12
    786
    Quote Originally Posted by pouellet View Post
    PO
    DATALINK was new for AutoCAD 2008
  1. Replies: 5
    Last Post: 2011-03-31, 06:32 PM
  2. Replies: 9
    Last Post: 2010-05-03, 09:19 PM
  3. Excel Table to AutoCAD Table.
    By Spenner in forum AutoCAD Tables
    Last Post: 2009-05-20, 03:04 PM
  4. Need Help, Trying to use excel formulas in AutoCAD Table
    By ReachAndre in forum AutoCAD General
    Last Post: 2008-08-04, 02:45 PM
  5. Export and Import to Excel and AutoCAD
    By avinash00002002 in forum AutoLISP
    Last Post: 2006-10-18, 12:04 PM
