Results 1 to 6 of 6
Thread: shadow studies with different color shadow
    100 Club sami's Avatar
    2008-09
    Toronto, Canada
    149
    Default shadow studies with different color shadow
    Does anyone know if there is a way to do shadow studies where one building casts a different color shadow from the rest of the buildings?
    In the past I have used ArchiCAD to create my shadow studies, I would do two versions one with our building and one without then use Photoshop to manually change the color of our building.. I’m hoping there is a better way in Revit..
    Sami Kazemi
    Architect, OAA, LEED AP
    Toronto, Canada
    www.kazemi.ca
    Revit Architecture 2011, Windows XP
    AUGI Addict Andre Carvalho's Avatar
    2006-06
    Toronto, ON
    2,386
    Default Re: shadow studies with different color shadow
    Unfortunatelly no.
    Andre Carvalho
    Revit Technical Specialist - Autodesk Scott Davis's Avatar
    2003-04
    Chino, CA
    4,743
    Ecotect will do this.
    Scott D Davis
    AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    I could stop if I wanted to Norton_cad's Avatar
    2007-05
    Bardwell Valley, Sydney, Australia
    434
    You could render the image without the new building, setting the sun colour as the default. Then add your new building, change the colour of the Sun, and re-render it. You can't superimpose one render on top of the other though. Just a before & after.
    You can superimpose a non-rendered 3D view, but can't change the colour of the shadows. Adding Shadows to the Visability Graphics annotation tab would be a good improvement. Also the ability to export to ACAD, with the shadows interperated as a solid fill with a high transparency, would be good as well. Then at least in ACAD you could manually change the colour. Maybe next release......
    Ohm's Law - Electricity follows the path of least resistance.
    Regards,
    Mark Norton,
    2008-09
    Toronto, Canada
    149
    some discussion on this same topic here:
    http://forums.augi.com/showthread.ph...shadow+studies
    I think I will try my hands at Ecotect for future projects, hope it integrates well with Revit..
    Sami Kazemi
    Toronto, Canada
    www.kazemi.ca
    2005-07
    Somewhere in the BIM world
    3,147
    Definitely Ecotec, and pretty simple to do
    The integration is not bad at all for now. I'm looking for more improvements now that they bought the company
  1. Floor Plan Shadow Studies
    By amorie in forum Revit Architecture - General
    Last Post: 2010-05-05, 04:42 PM
  2. Shadow studies
    By Exar Kun in forum Revit Architecture - General
    Last Post: 2010-03-22, 09:20 PM
  3. Printing Shadow Studies
    By MTristram in forum Revit - Plotting/Printing/Exporting
    Last Post: 2007-11-28, 04:26 AM
  4. Accuracy of Shadow Studies
    By lhanyok in forum Revit Architecture - General
    Last Post: 2007-11-15, 06:42 AM
  5. Shadow Studies
    By kwong in forum Revit Architecture - General
    Last Post: 2004-06-17, 05:39 PM
