First, can the ARROW key be programmed in a list routine?
When you open a file and close it, AutoCAD asks if you would like to “Save Changes To (file path)”. Very good for safety! However, in the office, occasionally, I tend to open a bunch of files I would rather view on the workspace for better view. When I use the “Close All” function in the Window menu, I get (traditionally) “Save Changes To (file path).
Under normal circumstance, I will ALWAYS use the TAB key or use the right-arrow key to move my action to “NO” so the current file would not be saved. Is there a way to suppress this request dialog box from showing and just close the opened drawing (by adding the arrow-key function in my toolbar button)? If so, what would be the function in programming to use?
