Thread: Share
    2004-07
    64
    Default Share
    Hi everybody
    We have 2 cmprs connected to a hub. But only one cmpr can share the printers and hard-drive. The other cmpr, even though, I set its properties for printer and hard drive to share, it still does not share. I notice the icon of c_drive in that cmpr does not have a hand underneath.
    Please help me fix the prolem. Its is unconveinence to switch cmpr everytime I want to plot.
    Thanks for yours respond.
    MT
    2015-12
    Arizona
    2,478
    Default Re: Share
    You are going to need to run the network setup wizard on the non-sharing computer
    and be certain that both machines are part of the same work-group.
    You will most likely need to reboot after running the wizard, and then your network
    resources should be available on both computers.
    2000-06
    159
    Default Re: Share
    after you make it a shared device, you should make sure both cad stations are using the same plotter and pens (ctb), from a shared subdirectory (point the paths - in options area), so it won't continue to look for the ctb and pc3, on the "other" cad station.
  1. How do you share?
    By jbenoit44 in forum BIM Management - General
    Last Post: 2011-03-24, 07:01 AM
  2. Any have old Afralisp they can share?
    By cadman_meg in forum AutoCAD General
    Last Post: 2008-07-24, 04:47 PM
  3. What do you share?
    By wmullett in forum Revit - In Practice
    Last Post: 2008-04-28, 01:25 PM
  4. Best way to share?
    By sschleper in forum Project Navigator
    Last Post: 2008-01-29, 07:30 AM
  5. To share or not to share . . . that is the question
    By crispin.schurr in forum Revit Architecture - Families
    Last Post: 2007-05-18, 03:24 AM
