I've upgraded to ADT 2005 and my Adobe Acrobat 6 Pro toolbar is no longer available. Does anyone know if they are compatible or not?
I belive that they are, you may need to un-install and re-install
Acrobat such that it will load it's toolbars in your installed
applications.
Unfortunately it didn't work. I wonder what will.
Thank you!
Hi Federico
i have on my pc ADT 3.3 and ADT 2005 and the Acrobat toolbar appear only in ADT 3.3.
But for me isn't a problem.
If i need a PDF from a ADT model, i print on a EPS file and then drag the EPS file in Distiller window, the time is less than make directly from ADT a PDF file.
Regards
