P.S. actually this is still under non disclosure: AutoCAD 2011 will have a Bonnet with two Ribbons![/quote]
2011 may need some flowering up before release
CADSTORM, you are the "King of the Lab" fixed my problem right away. Thanks for being there, man!
To solve this problem you can follow this simple steps:
1. On the command line area, right-click and select "Options".
2. Select "Profile" tab and there select <<ACAD>> profile and select it current profile "Set Current".
3. Slect Ok and Close.
Your Ribbon shoud to be back on screen.
R. Robert Bell
Design Technology Manager
S P A R L I N G
Opinions expressed are mine alone and do not reflect the views of Sparling.
Neither Cadstorm's nor Robert Bell's solution fixed the problem for me. I'm trying to fix a LDT Companion 2009 installation that lost its panels and tabs when I loaded a partial menu. I sure wish I knew why this happens.
Tom
Type "menu" in the comand bar.
Select the "Support" folder right of Look in:
Select one of the ".cuix" files
Note if it is a ".bak.cuix" it may not work.
Then click open.
This worked for me hope it works for you.
Thanks RobertB! Frustrating when things disappear randomly. That was a quick and easy fix!
