Thread: Soften out polylines....??
    2008-02
    Los Angeles, CA
    248
    Question Soften out polylines....??
    I have a topo file that was exported out of ArcGIS to AutoCAD...now i need to clean up the contour lines and make them less choppy (see attached screen shot)these way i can export it into 3dmax or revit to created a 3d model. so if anyone knows how to soften the ploylines let me know please.
    Thanks
    2005-06
    22
    Default Re: Soften out polylines....??
    With the PEDIT command you can choose the Spline option. PEDIT Quick Reference discusses what the option actually does. The original line is saved so you can go back to it if you don't like the results.
    If you still have access to the points you used to draw the topo you might want to try using another different command called SPLINE which draws true B-splines and has options that give you more control over the fit of the curve to the original points.
  1. Shadows... how to soften edges?
    By FWSchreck in forum Revit Architecture - Families
    Last Post: 2011-10-17, 04:43 PM
  2. Polylines with arcs to polylines with segments
    By randyspear in forum AutoCAD General
    Last Post: 2009-04-15, 06:22 PM
  3. Soften out polylines....??
    By mickaeL_renauD in forum AutoCAD Map 3D - General
    Last Post: 2008-11-06, 06:14 PM
  4. Replies: 7
    Last Post: 2008-02-22, 04:13 PM
  5. AutoCAD polylines to 3d polylines
    By neil_morrish in forum AutoCAD General
    Last Post: 2004-07-22, 10:40 AM
