Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Duct System Inspector
  1. #11
    2008-07
    203
    Default Re: Duct System Inspector
    Quote Originally Posted by cris8096 View Post
    Make a Vav Family with Reheat and a Vav Family without..
    I was just getting ready to start that. Thank you for your help Chris.
  2. #12
    Member David-Allan's Avatar
    2010-10
    Cape Town, South Africa
    21
    Angry Re: Duct System Inspector
    Howzit,
    I've just loaded Revit Mep 2011 and was thoroughly enjoying it until I reached a point where I needed to use the System Inspector... Now I have a headache...
    The main reason for it failing's because of the classic not "well connected" error which in 2010 and with AUGI's help I was able to solve regularly. Now, it just WILL NOT work... I've included the project hoping that someone out there could lend me a hand. It's very simple and the point of it is to check the pressure drops through out the system's ducting and the total so that my boss may choose a relevant fan. So: first we have the 4 grilles sucking in air to a "Reverse Pulse Unit" which is basically a big filter and where most of the pressure (750Pa) is dropping and then it leaves the RPU through a fan (which is just a thumb suck fan to test this all out with) and then to ducting which will leave the system through a grille. Now, firstly my 4 grilles just WILL NOT connect preventing the System Inspector and secondly, I've made all the connectors Return Air, is this correct? Are we able to or should we add in an Exhaust Air connector somewhere, perhaps near the end? What about the Systems? Surely I can make this all into one system? I ask this because I've made the RPU (a filter) mechanical equipment (for lack of a better category) but am having trouble adding it with the fan and 5 grilles. Perhaps I've gone about this the wrong way? Any advice would be greatly appreciated!!
    "Nō aru taka wa tsume wo kakusu."
    (The talented hawk hides its claws)
    David-Allan Bezuidenhout
    E-mail: dbezuidenhout@cmbct.co.za
  3. #13
    2012-12
    thanx for help
  1. Automatic Duct Sizing on Part of a Duct System
    By smotamedi.230512 in forum Revit MEP - General
    Last Post: 2010-10-05, 12:26 AM
  2. HVAC System Inspector
    By draftingking in forum Revit MEP - General
    Last Post: 2010-03-10, 03:24 PM
  3. Duct system
    By rkitect in forum Revit MEP - General
    Last Post: 2010-01-21, 01:19 AM
  4. 2010 System Inspector
    By sjsl in forum Revit MEP - General
    Last Post: 2009-04-29, 08:29 PM
