Thread: Quick Properties
    2004-07
    Detroit Michigan
    2,508
    Default Quick Properties
    Quick properties will not display no matter what I change. Any suggestions?
    2004-08
    Iron Station, NC
    3,198
    Default Re: Quick Properties
    dont use it, it only hogs system resources and slows productivity. On a more serious note, something that I have been guilty of, did you make sure you have it turned on? sorry to say, I spent a couple of hours a couple months ago trying to figure out why it wouldnt show up, when I finally realized it wasn't turned on. is it possible it is somehow off screen?
    2004-07
    Detroit Michigan
    2,508
    Hard to say. I booted up today and seem to missing the entire dashpanel, tabs, and quick properties isn't working. I was able to get all of my toolbars and lisp routines running.
    Something sacked AutoCad for a 15 yard loss today. Maybe a cui mistake?
    2004-08
    Iron Station, NC
    3,198
    Quote Originally Posted by Robert.Hall View Post
    Sounds like a reasonable assumption. I dont use any of the 3 items you listed, so I dont know that I could be much help. It almost sounds like someone confused a 2008 cui for a 2009 cui. What happens when you select the quick properties icon in the status bar?
    2004-07
    Detroit Michigan
    2,508
    I can turn it on/off using the icon. I do not see anything while working.
    I was able to create a custom panel for the dashpanel.
    All of the original panels are gone.
  1. 2015: Quick Properties Not Saving from NWF to NWD
    By mit81 in forum NavisWorks - General
    Last Post: 2015-06-19, 01:50 PM
  2. 2010: Properties and Quick Properties are gone from quick menu
    By daxxterrygreen822678 in forum AutoCAD LT - General
    Last Post: 2012-07-10, 08:56 PM
  3. Quick Properties
    By LogoKevn in forum AutoCAD General
    Last Post: 2012-01-24, 10:45 PM
  4. quick properties panel
    By rmk in forum AutoCAD General
    Last Post: 2011-05-16, 01:44 PM
  5. Quick properties changes in 2010
    By ajzoch in forum AutoCAD General
    Last Post: 2009-10-20, 03:41 PM
