Thread: Contour Label Precision?
    2008-02
    4
    Unhappy Contour Label Precision?
    I have started working with CIV3D '08. I cannot seem to find where to adjust the precision of the contour labels. Any ideas?
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: Contour Label Precision?
    In the style (see attached image). Make sure you hit the BLUE ARROW in the Text Component Editor after you select what you want on the left side of the Text Component Editor.
    2008-02
    4
    Thumbs up Re: Contour Label Precision?
    Thanks, that did the trick after a bit of poking.
    2004-02
    Colorado
    1,986
    Poking? It should have been blatantly obvious. After all, it's only what, a convoluted setting hidden inside a dialog hidden inside a dialog hidden inside a Style buried in Toolspace. You had a problem finding that?
  1. Help With Contour Labeling Elevation Precision
    By aspencer.226869 in forum AutoCAD Civil 3D - General
    Last Post: 2010-08-13, 09:26 PM
  2. Elevation Label Precision
    By Raulmjr in forum AMEP General
    Last Post: 2009-02-12, 05:02 PM
  3. setting precision for point label style
    By ramirop in forum AutoCAD Civil 3D - General
    Last Post: 2009-01-28, 05:21 PM
  4. -0 contour label
    By Chad Smith in forum Revit Architecture - General
    Last Post: 2006-07-04, 11:59 PM
  5. Label Precision Values
    By shannon.summers in forum AutoCAD Civil 3D - General
    Last Post: 2004-11-16, 08:45 PM
