Thread: Zoom Problems
    2008-10
    Floriduh
    8
    Angry Zoom Problems
    UAGH!!! i don't know how to really describe this - so please bear w/ me...when i want to zoom in, it's like the dwg won't come closer. it will, but it disappears, or the void space goes totally blank- at least half of it. i don't know wot is going on, or how to fix it. i'm done w/ the design, but i still need to throw on dimensions, and then take some camera shots, maybe even a tour- but i can't get close enuf to see the structure.
    i know that didn't make any sense- but my problem doesn't....gggrrrr
    2004-08
    Hartford, Michigan
    3,086
    Default Re: Zoom Problems
    Quote Originally Posted by usandthekids View Post
    regenall? how are you zooming? window? rolling your mouse in? check zoomfactor system variable, mine is set to 60
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
    2008-10
    Floriduh
    8
    i've tried them all, and it just diappears... sooo frustrating. mine is set to 60 also.
    2008-03
    331
    I guess you are using ZOOMEXTENTS - It might not be disappering but it extends your view. Try ZOOMEXTENTS then Control + A (select all) then you will see grips which is where your drawing at. If you Zoom In on that grips and did not see anything try LAYTHW or LAYON. Now if everything is showing it is time that you fixed your drawing by Deleting some unnecesarry lines or moving it closer to each other. Also, Dimensioning Radius of an Arc will extend to the Center of the Raduis when using ZOOMEXTENTS.
  1. 2011: Zoom problems
    By steve.medlock249376 in forum AutoCAD General
    Last Post: 2011-06-15, 08:19 PM
  2. Display problems: Revit won't "zoom" past a certain point...
    By FWSchreck in forum Revit Architecture - General
    Last Post: 2009-10-01, 02:58 PM
  3. Zoom problems!!
    By terynl in forum ACA General
    Last Post: 2009-08-03, 03:59 PM
  4. Center Mouse Click Pan & Zoom Problems
    By kyler in forum ACA General
    Last Post: 2008-05-27, 01:18 PM
  5. Zoom All Problems
    By d.stairmand in forum Revit Architecture - General
    Last Post: 2006-12-10, 07:19 PM
