Results 1 to 10 of 14
Thread: Quarter of an aperture in a wall.
    Модератор - Форумов AUGIru Aleksandr Sett's Avatar
    2004-10
    Kiev. Ukraine.
    647
    Default Quarter of an aperture in a wall.
    How correctly to construct a quarter of an aperture in a wall? With display in 3D. In ADT it " wall opening endcap ". Prompt please.
    2003-09
    1,907
    Default Re: Quarter of an aperture in a wall.
    Can you illustrate? - I'm dense - I don't follow..
    Revit Family Guy adegnan's Avatar
    2003-04
    DeForest, WI
    633
    I suspect this belongs in the "general" forum?
    willbeone, this forum is for "real life" construction discussion. Revit-specific questions belong in the "general" revit forum.
    And sorry that I can't answer as I do not understand your goal, either!
    2003-04
    Scotland
    1,577
    Can you post an example of what you mean by Aperture?
    to make cut out shapes in a wall you would use a VOID, in a FAMILY and use the CUT GEOMETRY command.
    AUGI Addict Andre Baros's Avatar
    2003-12
    Point of no return
    1,611
    Sounds to me like an issue of wall wraps. If you have an aperture in a wall, an opening, you can control the end caps of the wall at the opening with the "wraps" setting in the wall properties. When you edit the structure of a wall you can set which layers wrap over the end and which stop short.
    AUGI Addict PeterJ's Avatar
    2003-04
    London, UK
    1,948
    You mean an aperture that is a whole entirety but only cuts one quarter the depth of the wall?
    You could use an inplace family with a void that cuts the wall - this should be fairly straightforward tutorial stuff - or if the pattern repeats you could use a wall hosted family doing the same thing - again pretty much straight from the tutorials.
    I could stop if I wanted to Nic M.'s Avatar
    2001-11
    Antwerp, Belgium
    480
    do you mean this?
    Just guessing..
    same window family, done with voids
    2004-10
    South Africa
    3
    I’m an old hat with AutoDesk products Acad and ADT but relatively new to Revit, so still going through a teething period. I am ecstatic about what I see Revit can do with seemingly les or little effort. One thing that bothered me was cavity walls and how elements display with the open sides. When I saw your representation I was thrilled. Can you please tell me how it is done? Much appreciated.
    2004-10
    Kiev. Ukraine.
    647
    Question Re: Quarter of an aperture in a wall.
    Thanks.
    I shall try to understand.
    If it is possible send an example of family.
    2003-09
    1,907
    Bluegreen,
    Welcome aboard. In your wall definitions, (when you edit how a wall is constructed), right below the listing of materials to make up your wall is a table of "default wrappings". This is where you select how Revit is to treat openings and the end of walls. Enjoy..
  1. aperture osnap
    By mattcummins in forum ACA General
    Last Post: 2010-10-11, 07:32 PM
  2. Replies: 3
    Last Post: 2006-09-28, 06:20 PM
  3. Quarter of an aperture in a wall.
    By Aleksandr Sett in forum Revit - In Practice
    Last Post: 2004-10-05, 12:10 PM
  4. Aperture Flexibility
    By cadplans.71907 in forum Revit Architecture - Wish List
    Last Post: 2004-08-17, 05:40 PM
