Thread: Profile View Label Text
    2008-11
    22
    Question Profile View Label Text
    How can I get my profile view text to flip? My problem is shown in the attachment. When the label is dragged below the profile all the text bunches together. This attachment is just an example of what I am talking about, the label in this drawing does not need to be moved below the profile, but I have some others that do. Also, how can I edit the circled label?
    Thanks
    2008-03
    Laurel, MD
    509
    Default Re: Profile View Label Text
    You are reffering to your Vertical curve label, correct? Which text would you like to flip? You can adjust your label style to have the text in a position where it won't overlap. this would be changed in your vertical curve label style.
    2008-11
    22
    Yes, the verical curve label. Thanks for your help.
    2008-11
    22
    I would like to flip the k-value, pvi station, etc. to the bottom of the line instead of it being on the top. Thanks.
    2008-03
    Laurel, MD
    509
    You would change this in the text object offset of the style. I don't belive it's effected by it's location on the profile. You may want one style for above and one for below and you would simply swap them as needed.
  1. structure label dimension anchor point-profile view
    By Fred.Spinnenweber in forum AutoCAD Customization
    Last Post: 2008-04-17, 03:28 PM
  2. Pipe Label in Profile View
    By KansasCAD in forum AutoCAD Civil 3D - Pipes
    Last Post: 2007-08-21, 09:59 PM
  3. Profile View Label Ref. Prof. View Sta. Range problem
    By KansasCAD in forum AutoCAD Civil 3D - Profiles
    Last Post: 2007-05-22, 05:47 PM
