Is it possible to automatically put distance and bearing labels on each property line or is this usually done manually?
Thanks Bill
Thanks Bill
Bill,
I posted this in the other thread you started:
You don't have to do it manually. You can load a property tag. Go to File > Load From Library > Annotations > Civil > Property Line Tag. Once loaded just go to Drafting menu > Tag > By category and select the property lines. If you want to do all lines at once, select Tag all not tagged > select Property Lines segment tags > all objects in the current view or selected objects in the current view.
I hope it helps,
Andre Carvalho
