I need to create custom pipe systems. I need to have a different line style/pattern for several different systems. Has anyone figured this out, sorry if this has been discussed before. Any and all help would be great. thanks.
fairly simple
"other"
you can make all the differant systems you need
you will have to have some sort of fixture or equipment with a connector or a stand alone connector
then filters for looks (color, pattern(linetype), etc)
if you have created hydronic or sanitary or hot or cold water systems it is really not much different
use the help or tutorials
You can use filters.
1. Create a filter for every desired system type in the project.
2. Open a view with the systems
3. Go to Vesability/Graphics
4. Go to Filters tab
5. Add desired filters and define overrides for color and line type
Hope it will help.
