Thread: reactor in entity
    2001-07
    319
    Default reactor in entity
    Hello
    In a dwg I've "entget" an entity. In the return list I get the following list :
    (102 . "{ACAD_REACTORS") (330 . <Entity name: 7803b6a0>) (102 . "}")
    I probably should take a good look in the help file but could someone tells how it works? and how could I use this (above) one?
    Thanks
    100 Club matt.worland's Avatar
    2015-12
    Denver, CO USA
    174
    Default Re: reactor in entity
    An object reactor allows Lisp to watch an object for modifications. For a better explanation and example, look in AutoCAD's Developers Help file for vlr-object-reactor
    2001-07
    319
    Thanks I'll take a look
  1. vlr-dwg-reactor issue MY FIRST REACTOR
    By treaves04413213 in forum AutoLISP
    Last Post: 2013-10-18, 12:36 PM
  2. Replies: 0
    Last Post: 2013-06-20, 08:03 AM
  3. command reactor selected entity
    By Serhan_BAKIR in forum AutoLISP
    Last Post: 2012-01-13, 01:10 PM
  4. Replies: 1
    Last Post: 2009-08-14, 01:05 PM
  5. Proxy Entity Code 310 to Normal Entity
    By KevinBarnett in forum AutoCAD General
    Last Post: 2005-05-26, 07:21 AM
