Thread: How to: Map 3D DWG render matl's to Revit/MR materials
    100 Club Graham Briggs's Avatar
    2006-02
    Arcadia, CA
    117
    Default How to: Map 3D DWG render matl's to Revit/MR materials
    Can anyone shed some light on a successful method of mapping 3D DWG rendering materials to RAC09 // Mental Ray materials.
    Manufacturer's content is still much more common in the DWG format, but importing it into Revit families, and placing in a project to be rendered does not yield good results.
    Many times the DWG file has only two layers (0 and ASHADE), so I'm at a loss...
    TIA
    Graham
    2003-11
    442
    Default Re: How to: Map 3D DWG render matl's to Revit/MR materials
    Graham,
    You'll need to create and assign layers in the DWG that correspond to each material you want. Then in Revit, you assign the MR materials to the layers via Settings > Object Styles... > Imported Categories.
    HTH.
    2006-02
    Arcadia, CA
    117
    I don't use ACAD except when I have to, so am not terribly familiar...
    The plumbing fixtures I am working on are block referenced onto Layer 0, so I assume they should be exploded, and then the resulting polymeshes and faces placed on separate layers? Color by layer, etc.
    What a PITA
    It's too bad the Factory doesn't come up with an easier solution, say through the Labs, or as an Extension. There is a lot of acceptable content that could be morphed into true RFA's.
    Thanks for the advice.
    2003-11
    442
    Quote Originally Posted by Graham Briggs View Post
    What a PITA
    Yes. And as far as I know, that's the only way to do it.
  1. 2015: Can I render in Revit 2015 without materials?
    By sl308682163 in forum Revit Architecture - General
    Last Post: 2014-11-06, 02:28 PM
  2. 2014: Materials in render
    By Hexdown in forum Revit Architecture - General
    Last Post: 2014-10-13, 09:11 PM
  3. Importing Sketchup files to Revit and asigning render materials
    By Andrew Dobson in forum Revit Architecture - General
    Last Post: 2014-06-18, 05:08 PM
  4. Add Materials to Render Library
    By azmz3 in forum Revit Architecture - General
    Last Post: 2009-06-08, 11:31 PM
  5. Revit 8 --> Viz 2005 Matl Maps
    By captainbunsaver in forum Revit - Rendering
    Last Post: 2005-05-06, 03:36 PM
