Thread: trim a wall to a roof?
    2008-07
    6
    Default trim a wall to a roof?
    How do I trim a wall to a roof? I'm using Autocad Architecture 2008.
    -Michael
    2006-12
    Big "D"
    3,711
    Default Re: trim a wall to a roof?
    Quote Originally Posted by gustavson.michael View Post
    -Michael
    Michael,
    Just FYI, you're in the wrong forum. There is an ACA forum here http://forums.augi.com/forumdisplay.php?f=379
    If you post there, you will get quicker responses. Especially with wall, since vanilla CAD doesn't have them.
    Now on to your question. Select the wall or walls, then:
    right click > roof / floor line > modify roof line.
    Once there, there are sevaral options. Some work for some situations. The first on to choose is Auto Project. Just pick the roof and the walls should trim to it. If you have a complicated roof, you may have to do each wall separately.
    There is also a nifty command called Project to Polyline. You can go to a side view and draw a pline for the trim plane, then choose that command and project your wall to that pline.
    Hope that helps.
  1. Making a tiled or slated roof trim overhang the roof line.
    By PeterJ in forum Revit Architecture - Tips & Tricks
    Last Post: 2019-12-23, 11:27 PM
  2. Getting window trim to cut through compound wall trim or sweep?
    By Nasko in forum Revit Architecture - General
    Last Post: 2013-02-14, 04:49 PM
  3. trim a wall to roof
    By gustavson.michael in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-11-14, 10:17 PM
  4. Trim wall sweep to roof
    By msg4amer in forum Revit Architecture - General
    Last Post: 2007-02-01, 03:32 AM
  5. Roof and Trim
    By dsw98 in forum Revit Architecture - General
    Last Post: 2006-11-10, 07:28 PM
