I have many polylines in drawing, is it possible to write length and area of every single polyline on them, as text value.
Thanks...
Marijan
Thanks...
Marijan
simple answer, yes. The solution however, is a bit more complicated. First you need to select all the objects, and then look at the length and area properties of each one, creating a piece of text that contains this information. where would you like the text to appear, at the start, midpoint or end of the object? does it need to be rotated to match the polyline at that point, or can it be at any angle. does it need to be on the object? what type of precession do you need?
Christopher T. Cowgill, P.E.WIGHTMAN & ASSOCIATES, INC.
ENGINEERING <> SURVEYING <> ARCHITECTURE
AutoDesk Infrastructure Design Suite Premium 2013 x64
Windows 7 Pro x64
Thak you for your answer!
-where would you like the text to appear, at the start, midpoint or end of the object?
Lets say mid point,or somewhere not far from polyline, because there is great number
of them, so midpoint is good solution.
_does it need to be rotated to match the polyline at that point, or can it be at any angle.
Any angle, because i export this to excell,... so any angle
_does it need to be on the object?
Its good solution because there is great number
of polylines,..
_what type of precession do you need?
type of precession,... four decimal spaces for area and length
Thanks,...
Marijan
What format do you need the text to appear in for exporting to excel? You can give this a shot and see if gets you started in the right direction, obviously it isnt taylor-made for your situation, but if you can do any modifying, it should give you a very good start:
I havent tested it, it may not even work, and it is currently set up to use our office standardsCode:(defun c:lengthareatext (/ lengthmode object objchk listobj vlobj MidPoint Param startpline endpline vlobjlen1 angle1 Ang TH vlobjang textobj1 textobj2 vlobjang1 vlobjang2 lengthscale ) (setq lengthscale (atoi (vl-string-left-trim ":" (vl-string-left-trim "1234567890" (getvar "cannoscale")))) ) ;_ end of setq (while (setq listobj (ssname object 0)) (setq vlobj (vlax-ename->vla-object listobj)) (if (/= (cdr (assoc 0 (entget listobj))) "ARC") (setq vlobjlen1 (vla-get-length vlobj) objchk 1 ) ;_ end of setq (setq vlobjlen1 (vla-get-arclength vlobj) objchk 2 ) ;_ end of setq ) ;_ end of if (setq MidPoint (vlax-curve-getpointatdist vlObj (/ vlobjlen1 2) ) ;_ end of vlax-curve-getpointatdist Param (vlax-curve-getParamAtPoint VlObj MidPoint) startpline (vlax-curve-getStartParam VlObj) endpline (vlax-curve-getEndParam VlObj) angle1 (vlax-curve-getFirstDeriv VlObj (/ (- endpline startpline) 2) ) ;_ end of vlax-curve-getFirstDeriv TH (* 0.08 lengthscale) ) ;_ end of setq (if (= objchk 1) (progn (if (equal (car angle1) 0.0 0.01) (setq Ang (/ pi 2)) (setq Ang (atan (/ (cadr angle1) (car angle1))))) (setq vlobjang (angtos Ang 4 3) vlobjang1 (vl-string-left-trim "NS 0123456789" vlobjang) vlobjang2 (vl-string-right-trim "EW \"0123456789'" vlobjang) vlobjang2 (vl-string-right-trim "d" vlobjang2) vlobjang (strcat vlobjang2 "%%" vlobjang1) ) ;_ end of setq ) (setq Ang (- (/ (+ (vla-get-endangle vlobj) (vla-get-startangle vlobj) ) ;_ end of + 2 ) ;_ end of / (/ pi 2) ) ;_ end of - vlobjang (angtos Ang 4 3) vlobjang1 (vl-string-left-trim "NS 0123456789" vlobjang) vlobjang2 (vl-string-right-trim "EW \"0123456789'" vlobjang) vlobjang2 (vl-string-right-trim "d" vlobjang2) vlobjang (strcat vlobjang2 "%%" vlobjang1) ) ;_ end of setq ) ;_ end of if (if (wcmatch (rtos vlobjlen1 2 4) "*`.*") (setq vlobjlen (strcat (rtos vlobjlen1 2 4) "'")) (setq vlobjlen (strcat (rtos vlobjlen1 2 4) ".0000'")) ) (setq textObj1 (vla-addtext acadModelSpace (strcat vlobjlen " " (vla-get-area vlobj)) (vlax-3d-point Midpoint) TH ) ;end vla-addtext ) ;end setq (vla-put-color textobj1 256) ;change color (vla-put-alignment textobj1 13) ;change justification (vla-put-textalignmentpoint textobj1 (vlax-3d-point Midpoint) ) ;_ end of vla-put-textalignmentpoint ;change insetion point (vla-put-rotation textobj1 Ang) ;change rotation (vla-put-layer textobj1 "Annotation") (if (/= textObj2 nil) (progn (vla-put-color textobj2 256) (vla-put-alignment textobj2 13) (vla-put-textalignmentpoint textobj2 (vlax-3d-point (list (+ (car Midpoint) (* (sin ang) (* 0.16 lengthscale))) (- (cadr Midpoint) (* (cos ang) (* 0.16 lengthscale))) (caddr Midpoint) ) ;_ end of list ) ;_ end of vlax-3d-point ) ;_ end of vla-put-textalignmentpoint (vla-put-rotation textobj2 Ang) (vla-put-layer textobj2 "Annotation") ) ;_ end of progn ) ;_ end of if (ssdel listobj object) ) ;end while ) ;end defun
Windows 7 Pro x64
HI!!
Thank You for instant reply!
I have try it but there is error at startin the app
acad command line: Command: lengthareatext
; error: bad argument type: lselsetp nil
Thanks anyway!!
Marijan
well I have fixed all the errors, but I dont think the rotation for the text is workingCode:(defun c:lengthareatext (/ lengthmode object objchk listobj vlobj MidPoint Param startpline endpline vlobjlen1 angle1 Ang TH vlobjang textobj1 textobj2 vlobjang1 vlobjang2 lengthscale vlobjarea1 ) (setq object (ssget (list (cons 0 "POLYLINE,*CONTOUR,ARC,LINE,LWPOLYLINE,2DPOLYLINE" ) ;_ end of cons ) ;_ end of list ) ;_ end of ssget lengthscale (atoi (vl-string-left-trim ":" (vl-string-left-trim "1234567890" (getvar "cannoscale")))) ) ;_ end of setq (while (setq listobj (ssname object 0)) (setq vlobj (vlax-ename->vla-object listobj)) (if (/= (cdr (assoc 0 (entget listobj))) "ARC") (setq vlobjlen1 (vla-get-length vlobj) vlobjarea1 (rtos (vla-get-area vlobj) 2 4) objchk 1 ) ;_ end of setq (setq vlobjlen1 (vla-get-arclength vlobj) objchk 2 ) ;_ end of setq ) ;_ end of if (setq MidPoint (vlax-curve-getpointatdist vlObj (/ vlobjlen1 2) ) ;_ end of vlax-curve-getpointatdist Param (vlax-curve-getParamAtPoint VlObj MidPoint) startpline (vlax-curve-getStartParam VlObj) endpline (vlax-curve-getEndParam VlObj) angle1 (vlax-curve-getFirstDeriv VlObj (/ (- endpline startpline) 2) ) ;_ end of vlax-curve-getFirstDeriv TH (* 0.08 lengthscale) ) ;_ end of setq (if (= objchk 1) (progn (if (equal (car angle1) 0.0 0.01) (setq Ang (/ pi 2)) (setq Ang (atan (/ (cadr angle1) (car angle1))))) (setq vlobjang (angtos Ang 4 3) vlobjang1 (vl-string-left-trim "NS 0123456789" vlobjang) vlobjang2 (vl-string-right-trim "EW \"0123456789'" vlobjang) vlobjang2 (vl-string-right-trim "d" vlobjang2) vlobjang (strcat vlobjang2 "%%" vlobjang1) ) ;_ end of setq ) (setq Ang (- (/ (+ (vla-get-endangle vlobj) (vla-get-startangle vlobj) ) ;_ end of + 2 ) ;_ end of / (/ pi 2) ) ;_ end of - vlobjang (angtos Ang 4 3) vlobjang1 (vl-string-left-trim "NS 0123456789" vlobjang) vlobjang2 (vl-string-right-trim "EW \"0123456789'" vlobjang) vlobjang2 (vl-string-right-trim "d" vlobjang2) vlobjang (strcat vlobjang2 "%%" vlobjang1) ) ;_ end of setq ) ;_ end of if (if (wcmatch (rtos vlobjlen1 2 4) "*`.*") (setq vlobjlen (strcat (rtos vlobjlen1 2 4) "'")) (setq vlobjlen (strcat (rtos vlobjlen1 2 4) ".0000'")) ) (setq textObj1 (vla-addtext acadModelSpace (strcat vlobjlen " " vlobjarea1) (vlax-3d-point Midpoint) TH ) ;end vla-addtext ) ;end setq (vla-put-color textobj1 256) ;change color (vla-put-alignment textobj1 13) ;change justification (vla-put-textalignmentpoint textobj1 (vlax-3d-point Midpoint) ) ;_ end of vla-put-textalignmentpoint ;change insetion point (vla-put-rotation textobj1 Ang) ;change rotation (vla-put-layer textobj1 "0") (if (/= textObj2 nil) (progn (vla-put-color textobj2 256) (vla-put-alignment textobj2 13) (vla-put-textalignmentpoint textobj2 (vlax-3d-point (list (+ (car Midpoint) (* (sin ang) (* 0.16 lengthscale))) (- (cadr Midpoint) (* (cos ang) (* 0.16 lengthscale))) (caddr Midpoint) ) ;_ end of list ) ;_ end of vlax-3d-point ) ;_ end of vla-put-textalignmentpoint (vla-put-rotation textobj2 Ang) (vla-put-layer textobj2 "0") ) ;_ end of progn ) ;_ end of if (ssdel listobj object) ) ;end while ) ;end defun
Windows 7 Pro x64
OOOOPS!!!
again!
APPLOAD lengthareatext.lsp successfully loaded.
Command:
Command:
Select objects: 1 found
Select objects:
; error: bad argument type: VLA-OBJECT nil
Command:
Command: LENGTHAREATEXT
Select objects: 1 found, 2 total
Select objects: ; error: bad argument type: VLA-OBJECT nil
Command:
I just ran it on my system and here is the output:
You probably need to add (VL-LOAD-COM) to the beginning of the code. My office has this line in our main load file, so I always forget to put it in on individual programs.Command:
Select objects:
<Selection set: 82>
Command:
Windows 7 Pro x64
Hi!
Again;
Select objects: 1 found, 3 total
maybe is acad version, i work with 2008,..
