Thread: How can I insert a PDF into a DWG
    2004-10
    2
    Question How can I insert a PDF into a DWG
    how can i insert PDF file in to Autocad drawing file?is it possible to insert without changing it as a image file?answer please
    13,623
    Default Re: How can I insert a PDF into a DWG
    Hi
    Search and one will find - Search Forums
    To point you in the right direction take a look at the following thread -
    Insert pdf files into AutoCAD
    Have a good one, Mike
    2003-11
    442
    If the pdf is made from a vector format then you can use ghostscript and gsview to convert the pdf into a dwg.
    Houston
    9,303
    Lightbulb Re: How can I insert a PDF into a DWG
    Here are some applications that can assist in converting (or importing) a PDF into a DWG or DXF.
    R.K. McSwain | CAD Panacea |
  1. Insert DWG in DWG via vb.Net
    By drewj in forum Dot Net API
    Last Post: 2012-12-03, 05:01 PM
  2. Map Insert VS FDO
    By jenniferchavez in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2010-01-12, 11:08 PM
  3. Insert Sheet List - Won't insert
    By chris.klinert in forum ACA General
    Last Post: 2008-12-18, 03:45 PM
  4. Insert OLE
    By a.r.t.studio in forum AutoCAD General
    Last Post: 2005-07-07, 10:59 PM
  5. Name that insert
    By Maverick91 in forum AutoCAD General
    Last Post: 2005-06-14, 01:25 PM
