Results 1 to 7 of 7
Thread: Local file not compatible with central
    100 Club chris.macko's Avatar
    2006-10
    Chicago, IL
    133
    Default Local file not compatible with central
    We've been having some problems lately with one users local file randomly giving her the error that her file has become incompatible due to the same object being edited in both files. There are 3 of us working on the project right now, all with our own local files saved on our workstations. This happened yesterday too, but since there weren't any major changes made since it last saved successfully, we just created a new central file and made new locals from there. This time there were more changes by both users so we would be losing some work by throwing away the local.
    Has anyone had this kind of thing happen? I thought revit wouldn't even allow 2 users to edit the same element, so i'm confused as to why this is happening at all. We are using 2008 and nobody has been working in the central file other than to create locals.
    Pittsburgh, PA USA
    1,906
    Default Re: Local file not compatible with central
    Chris, What type of network, are there athentication servers being mirrored? How fast is your network, and are you using the Worksharing monitor? How may Revit or AutoCAD files are linked in, and have you imported any AutoCAD files? How big is the central file?
    100 Club xiqx's Avatar
    2007-02
    Netherlands
    140
    Could it be that someone has been accidentally working in the central file?
    2007-06
    Chesterfield, MI
    378
    I've seen this happen when a user accidently opens the Central file for editing.
    2006-01
    4,516
    Ive also seen this happen when two users have the same "name" under Settings > Options.
    Basically, one person is invalidating the other persons work. Check all the users names and make sure no two are the same...
    The above post is by a user not frequenting the site. Questions regarding post:
    Send to: aaron@aaronmaller.com (include text of post). Thanks.
    2006-10
    Chicago, IL
    133
    Quote Originally Posted by twiceroadsfool View Post
    Looks like that was the problem. Two us recently had to reinstall revit due to some graphics driver issues and they had to be installed by the administrator. So sure enough, revit picked up that login name as its username.
    Such a simple fix too. Thanks for the catch!
    2006-01
    4,516
    ive done that myself a bunch of times, thats why i figured it was that.
    Glad you got it sorted out...
  1. 2012: Local file synch to Central file on temporary server
    By amradcliff in forum Revit Architecture - General
    Last Post: 2012-03-29, 11:22 AM
  2. Local File No Longer Compatible
    By twollifur in forum Revit Architecture - General
    Last Post: 2010-05-21, 05:36 PM
  3. Local File Incompatible with Central File - Revit 2010 Error??
    By ekneer in forum Revit Structure - General
    Last Post: 2010-02-18, 02:51 PM
  4. Recreating Local File from Central - requires new file name?
    By Haden in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2005-09-23, 06:15 AM
  5. How do I save Local Client file to become Central file?
    By Richard McCarthy in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2004-03-29, 05:44 AM
