Thread: Does anyone have the find replace routine as a lisp file that can be used with run batch?
    2008-11
    12
    Cool Does anyone have the find replace routine as a lisp file that can be used with run batch?
    Guys,
    I would like to use the "FIND" command in a simply lisp file that i can than use with runbatch on 600dwgs. The command doesn't seem to have a command line option and only through the dialog box. Is there away around this or someone have this function they could share?
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    Default Re: Does anyone have the find replace routine as a lisp file that can be used with run batch?
    Google chtext.lsp
    : ) Happy Computing !
    kennet
    Earth
    9,805
    Also, ToolPac includes a utility for find/replace across multiple drawings without using a script file.
    R.K. McSwain | CAD Panacea |
    2007-03
    Huntingdon, TN
    97
    I just went through that same thing last week. This is what I ended up using.
    2008-11
    12
    Cool Re: Does anyone have the find replace routine as a lisp file that can be used with run batch?
    Much appreciated, thanks guys.
  1. find and replace in lisp
    By ReachAndre in forum AutoLISP
    Last Post: 2009-03-09, 03:54 PM
  2. Find / Replace lisp
    By BCrouse in forum AutoLISP
    Last Post: 2008-04-16, 05:15 PM
  3. Using find and replace text in lisp
    Last Post: 2007-07-16, 05:33 PM
  4. A LISP routine for runing a batch file ?
    By stephen.coff in forum AutoLISP
    Last Post: 2006-09-07, 02:40 AM
