Thread: How to show "last printed" or "path" text in layout
    2008-01
    6
    Default How to show "last printed" or "path" text in layout
    I've seen it in other drawings, but I have no clue how to do it or what it's called (so searching for it didn't work for me).
    What I am looking for is how to have text in my layout view that shows the date and time of when the drawing was sent to the printer. I don't want to have to type this text manually, I would like it to update automatically. I've seen similar setups in drawings before, but I don't know how to get it to work.
    If someone could point me in the right direction it would be great. Thanks.
    0,0,0 The Origin
    8,570
    Default Re: How to show "last printed" or "path" text in layout
    PLOTSTAMP.
    In the plot dialogue there is a check box labeled "Plot stamp on".
    2008-03
    383
    Or you can use a FIELD. Under INSERT Menu chose FILED then use the PLOT Filed Category.
    AUGI Director scott.wilcox's Avatar
    2015-11
    Edmonton, Alberta
    990
    You can also use RTEXT string such as:
    $(GETVAR, "DWGPREFIX")$(GETVAR, "DWGNAME") - $(GETVAR, "CTAB") -$(EDTIME, 0, MON. DD"," YYYY H:MMam/pm) - $(GETVAR, "LOGINNAME")
  1. Replies: 0
    Last Post: 2012-06-06, 11:54 AM
  2. XREF "Saved Path" to "Found at" location
    By cadmancando in forum AutoLISP
    Last Post: 2012-01-18, 03:54 PM
  3. ENTIDADES EN ALIGNMENT COMO "FIXED", "FLOTING" y "FREE"
    By cadia in forum AutoCAD Civil 3D - General
    Last Post: 2009-02-01, 04:21 AM
  4. MEP beginner question: Mechanical "Layout Path" button
    By sven.129574 in forum Revit MEP - General
    Last Post: 2008-01-29, 12:44 AM
  5. Replies: 8
    Last Post: 2007-04-04, 12:39 PM
