Results 1 to 7 of 7
Thread: Slab edge not at wall moves on wall move.
    2007-10
    46
    Default Slab edge not at wall moves on wall move.
    Why does a slab edge move, when a wall moves, and the slab edge is nowhere near the wall?
    For example, we notice when a lift core wall is moved, a slab edge on the outside of the building will move, as well as the edge that is touching the wall.
    It is ok the slab edge on the wall moves with the wall. BUT IT IS DEADLY when the outside edges move as well. Sometimes we miss a change revit has done and it goes out wrong. Sometimes i think the parametric fuss if barley worth the fuss, with the amount of back checking and back editing you have to do.
    Does anyone have any techniques to resolve this?
    AUGI Addict Andre Carvalho's Avatar
    2006-06
    Toronto, ON
    2,386
    Default Re: Slab edge not at wall moves on wall move.
    Yes this happens often, when you create the slab opening in the slab sketch. You shouldn't have this problem if using the shaft opening tool.
    Andre Carvalho
    2007-10
    46
    True some of my early models I made this mistake. Still have a few issues even when shaft openings and opening by face are used.
    2005-10
    321
    Allan,
    I believe this is a critical issue with the software. Anytime you have a complex/compound slab edge moving elements can be a nightmare, and this gets exponentially worse with the number of independant floor slabs you have. The best solution I have found is to group your slab edges. This way moving other elements does not affect the slabs.
    I am hoping future releases of Revit have an option to disable this feature as a whole or at least per element.
    I will see if I can dig up a previous post regarding this.
    Here is a link to a more detailed thread discussing this
    http://forums.augi.com/showthread.php?t=89116
    2007-10
    46
    I would be supportive of your suggestion here. an option to turn the dynamic slab edge moving off. On major re-designs we would rather see what the slab was before not what the software dynamically changed it to. .... hope autodesk are reading hint hint
    I could stop if I wanted to FOUTJM's Avatar
    2005-12
    the island
    235
    are there constraints added during sketching of the slab?
    i have found this can be problematic.
    J Fout
    Artist, Revit Grunt
    "it is not the answer i seek, but to understand the question".
    @scribldogomega
    2006-09
    442
    Also if you use the pick wall tool for creating the slab edge, that will associate the sketch line with the wall.
  1. 2011: Multi-story exterior wall, trimming framing at slab edge
    By nrollins in forum Revit Architecture - General
    Last Post: 2011-08-15, 09:21 PM
  2. Slab edge moves with wall
    By brent.vanlelyveld in forum Revit Structure - General
    Last Post: 2009-02-05, 07:42 PM
  3. Slab Edge Profile not loading under Floor-Slab Edge
    By John Anderson in forum Revit Architecture - General
    Last Post: 2008-06-16, 05:44 PM
  4. WALL FOOTING STOPS AT EDGE OF WALL
    By khanson-3b in forum Revit Structure - General
    Last Post: 2006-09-19, 09:31 PM
  5. Wall edge stuck to floor edge
    By iru69 in forum Revit Architecture - General
    Last Post: 2006-03-02, 07:55 PM
