Thread: Text search and replace
    Wish List Administration
    2007-08
    603
    Default Text search and replace
    Summary: Ability to search all text per view as you can with the AutoCAD FIND command that allows a general search of text and replacing the text.
    Description: Ability to search all text per view as you can with the AutoCAD FIND command that allows a general search of text and replacing the text.
    This is similar to spell check except it finds each instance of the same text you're looking for in the entire view.
    How Used: It would be used to mass update multiple text notes and schedules quickly. For instance, if all instances of the note 3 5/8" needed to be changed in all 12 wall sections to 4" this command would be perfect for finding each instance of 3 5/8" and allowing you to change it to 4".
    Feature Affinity: Annotation tools
    Submitted By: Garfield Carey on July 23, 2008
    2008-06
    3
    Default Re: Text search and replace
    This would be really nice!! We are always changing wall section notes at the last minute. If we had this functionality it would save hours of flipping though every section to change one word in a repetitive call-out note.
  1. Enhanced Search and Replace options
    Last Post: 2013-11-15, 08:01 AM
  2. Autocad search & replace text
    By MarkLyon in forum CADmep General
    Last Post: 2012-11-05, 10:03 AM
  3. Search and Replace
    By GreenMan415 in forum Dot Net API
    Last Post: 2009-12-04, 06:41 PM
  4. Search for a Lisp to replace blocks
    By BCrouse in forum AutoLISP
    Last Post: 2008-10-14, 05:42 PM
  5. Text search and replace routine across multiple drawing files
    By David van Erk in forum AutoCAD Customization
    Last Post: 2006-05-19, 10:31 PM
