Results 1 to 10 of 18
Thread: residential roof question
    100 Club kshawks's Avatar
    2004-01
    Independence, KS
    120
    Default residential roof question
    I am working on a house project (see attached plan). For the most part the house has 10 foot high ceilings. however the entry foyer and dining room in the front of the house have 12' ceilings. the owner found a specific look for the front entry that they want me to mimic. I have tried to get this roof to work but I cant seem to get it. I can get the basic foot print completed for the majority of the house using roof by footprint. I use extruded roofs for the the 12 foot high roofs and that works okay there. The problem I seem to be having is how do i cut the main house roof from around the 12' roofs to get the look they are after.
    Any suggestions would be greatly appreciated.
    Sean
    2005-07
    Somewhere in the BIM world
    3,140
    Default Re: residential roof question
    Im not sure i understand hopw you build it. I also dont understand why you are using extrisoin. Can you post the floor plan please?
    I could stop if I wanted to Andy.88917's Avatar
    Midland, Texas
    222
    Just from my residential design experience I know you want to try and raise those plate heights high enough that the gables don't die into the roof like this because of the water trap or ugly cricket that would be required.
    On another note. I do roofs like this every day and this is one reason I cannot convince myself to move to revit. I do this easily in ACA all the time (and render it). Is this easy in Revit or as hard as I and dhurtubise think it is?
    All AUGI, all the time jetisart's Avatar
    2004-10
    Sunshine Coast, QLD, Australia
    607
    I think that the easiest way to create this roof would be to create two separate roofs and join them (see picture below). With more time and patience you could "sculpture" it from a single roof but I don't think it's worth the hassle.
    P.S. It took me about 10 minutes to work it out (including modelling the walls). If you have trouble let me know and I will walk you step by step
    2005-07
    3,140
    Just to correct. I never said it was a hard one. I was just asking for his actual construction to get an example together. As you can see Jerry beat me to it
    Don't think it's a big deal either. Well not one that is worth staying in ACA according to me
    2003-05
    North Texas
    105
    Boy, I feel sorry for the one using ACA for residential design. We tried it for several months and wanted to SCREAM every morning... You really ought to try out Revit... (free 30 month demo, you can get familiar with that).
    For the roofs, I often do separate roofs, and use the "Modelling/Opening/Vertical Opening" command to trim the roofs.
    Midland, Texas
    222
    Every couple of versions I give Revit a demo shot. I just can't keep up with my ACA and the customizations I have done. We are a firm of me and a draftsman and we are cranking out about 150 houses a year (including renderings on every job). If I could figure out how to customize Revit to do what I am doing already in ACA I might consider it but being so busy I don't have the time to spend on customizing Revit or even know if it's possible.
    2004-06
    Memphis TN area
    6,701
    Wow, 150 houses/year, even with the current economy? Yes there is a bit of a learning curve, but in the long run it would probably pay off, many times over. You should try getting into Revit if your work ever slows down at all.
    Intern Architect, BIM Manager/Coordinator
    AERC, PLLC
    Hernando, Mississippi
    Revit - all up in your voxel space
    Midland, Texas
    222
    To tell you the truth, my work has actually picked up in the last 3 months. It's crazy, tons to do and more coming in every day! In fact I am looking to hire another designer, just can't find the right person right now.
    I just pray that it keeps up until we are out of this economic crunch!
    I would love to see some examples of residential work done in Revit. It seems great for commercial but I have always thought the residential end of Revit is lacking.
    2008-10
    266
    I work for a company that mainly does industrial/prisons, and I am doing Two-Unit Condo, split level plan for an old client of the Principal Architects here, the only thing I had a problem with was getting the door tag to read the way the Architect wanted it, since Revit does not do Super/Sub Scripting like AutoCAD. Once I got a custome tag made, its no problem to go from REsidential to commercial and back again.
  1. Residential Roof
    By Jprisby in forum Revit Architecture - General
    Last Post: 2007-12-20, 08:38 PM
  2. Residential roof design
    By Mike Sealander in forum Revit Architecture - General
    Last Post: 2006-12-14, 01:05 PM
  3. Another residential roof
    By janunson in forum Revit Architecture - General
    Last Post: 2005-04-05, 02:08 PM
  4. Help with Residential Roof...
    By MRV in forum Revit Architecture - General
    Last Post: 2005-03-31, 10:44 PM
  5. Residential Metal Roof
    By max in forum Revit Architecture - General
    Last Post: 2004-08-02, 02:55 PM
