Results 1 to 10 of 15
Thread: remove all constraints at once?
    100 Club timothyjturner's Avatar
    2005-09
    Columbus, OH
    101
    Default remove all constraints at once?
    I am trying to rotate a title block. It seems quite impossible without removing the constraints. Is there a way to remove all constraints without actually clicking each individual one? There are hundreds! I'm trying to remove all so that I can rotate and then I will constain as needed. Thanks for your help.
    2008-09
    Central IL
    51
    Default Re: remove all constraints at once?
    If you are trying to change from a landscape to a portrait layout then you right click the sheet you want to change in the browser and select 'edit sheet', from there it should be very simple. I have never had to do what is sounds like you are trying to do, but maybe I am not understanding your request correctly.
    Hope this helps, Paul
    2005-09
    Columbus, OH
    101
    Quote Originally Posted by pauldoubet View Post
    I have one layout for a 11x17 landscape page. On this layout, my custom title block is rotated 90 degrees (so that you can read it, if you turn the page sideways).
    I am now trying to create an 8.5x11 portrait page. The problem is that when I switch to portrait and change the position of the title block. It does not rotate down to the bottom of my 8.5x11, like I'd like (i.e. - the title block is still rotated 90 degrees, like in the landscape).
    2008-09
    Central IL
    51
    I have quite a few custom title blocks. I will take a closer look and get back to you when I see what might be the best solution.
    Paul
    2008-09
    Central IL
    51
    I have attached a file showing the typical way of using edit sheet to change from a 11 x 17 landscape to 11 x 17 portrait. The same thing happens with any sheet size. Basically what you are seeing is a change of dimension for the border, there is no rotation of the border or title block required. Are you seeing some different behavior when you edit sheet? If so how did you go about creating the title block and sheet format?
    2005-09
    Columbus, OH
    101
    Yeah, here is a picture of the problem. I want the drawing to look exactly the same as it is in the first picture, but be in a portrait view instead of landscape.
    2015-12
    293
    I have had to remove all constraints individually as well when trying to do this. The only fix I came across was to create the titleblocks using a rotation parameter, ensuring there were no vertical or horizontal constraints applied automatically when sketching. If you use any sort of hatching or solid fill, you will probably have to re-apply it. I have had to in every case when I have done a rotation.
    I'm sure one of the VBA gurus can whip up a routine to remove all constraints, but then you will have to re-apply them all again. More fun than I want to have.. again..
    2008-12
    75
    Not 100% sure what you're trying to achieve, the files you attached showed a portrait and landscape border/title block with the title block in the same spot? am i right in saying you want a portrait view with the title block in the lower left corner?
    anyways, i had a play with some VBA and got you code to delete all constraints in the title block sketch definition... it's pretty slow but i can't be bothered trying to figure out why.
    I was going to be tricky and use autodimension to re-instate the constraints once rotated... but i can't seem to figure out how to access auto-dimension via the API... someone smarter might know how...
    Cheers
    Gerrard
    Sub DeleteTitleBlockConstraints()
    Set oDoc = ThisApplication.ActiveDocument
    Set osheet = oDoc.ActiveSheet
    Set otblockconst = osheet.TitleBlock.Definition.Sketch.GeometricConstraints
    On Error Resume Next
    Do While Not j = otblockconst.Count
        i = 0
        For Each kgeometricconstraints In otblockconst
            i = i + 1
            If otblockconst.Item(i).Deletable = True Then
                otblockconst.Item(i).Delete
            End If
        Next
        j = i
    Loop
    End Sub
    Williamsport, PA
    641
    Red face Re: remove all constraints at once?
    Quote Originally Posted by timothyjturner View Post
    Yes, upgrade to r2009.
    2008-12
    75
    Quote Originally Posted by JD Mather View Post
    Look at the attachment... he is using 2009, and the command is there in 2008 as well
    I tried that command last night at home (2009 SP1), and it didn't work... i'm trying it again now at work (2008, SP3), and it's painfully slow then doesn't work, i wouldn't recommend that command... i assume you've done the same, and it worked fine for you?
  1. Remove All Geometic Constraints
    By Bolknack in forum AutoLISP
    Last Post: 2012-11-30, 07:06 PM
  2. FEA Constraints
    By mankie1926260 in forum Inventor - General
    Last Post: 2011-08-11, 04:16 PM
  3. Constraints
    By ccowgill in forum Dynamic Blocks - Technical
    Last Post: 2010-11-30, 07:36 PM
  4. 2011: Remove all constraints in AutoCAD 2011
    By jason907238 in forum AutoCAD General
    Last Post: 2010-07-16, 12:21 PM
  5. Constraints: Sightline Based Constraints
    By ronjon in forum Revit Architecture - Wish List
    Last Post: 2005-01-11, 02:40 PM
