Results 1 to 7 of 7
Thread: grain direction
    2005-09
    Boston, MA
    15
    Default grain direction
    Hi guys,
    I'm attaching a picture of a render that I'm doing for a small project. We're using Zinc Composite panels and I can't seem to get the orientation of the Zinc grain in the right direction. We want the grain to go horizontally instead of vertically. Any suggestions/ comments are welcome. Thank you for reading my post.
    2003-11
    442
    Default Re: grain direction
    Add a parallel line surface pattern to your material. You can then rotate the surface pattern and the rendered material pattern will also rotate.
    2005-09
    Boston, MA
    15
    muttlieb,
    The surface pattern is already running horizontally. I added a surface pattern even before I started to render. The render is still going vertically.
    2003-11
    442
    Did you rotate the pattern? The direction of the surface pattern and the material pattern may not match.
    2005-09
    Boston, MA
    15
    I tried to rotate it but it gave me this error "Can't rotate element into this position.". I also tried switching between different surface patterns and I got the same error message.
    2003-11
    442
    Are you sure you're highlighting on a line of the surface pattern for rotation, and not trying to rotate the actual element?
    2005-09
    Boston, MA
    15
    I had to edit the generic model and rotate the pattern from inside the editor. I was able to rotate the surface pattern and when I rendered, the grains followed the correct direction. Thank you so much muttlieb.
  1. 2012: Wood Grain Vertical Veneer Pattern
    By Scott_Bloss in forum Revit Architecture - General
    Last Post: 2012-03-16, 12:31 PM
  2. Wood Grain Hatching Pattern
    By Curt340924 in forum AutoCAD General
    Last Post: 2012-02-01, 01:49 PM
  3. I need a direction here
    By burninin1 in forum Inventor - General
    Last Post: 2008-12-14, 05:54 PM
  4. Need Wood End Grain Pattern Drafting
    Last Post: 2006-02-02, 12:18 PM
  5. Looking for Hatch patterns - CUT STONE and END GRAIN
    By tom.millman in forum ACA General
    Last Post: 2004-10-15, 10:13 PM
