Thread: need help calculating pipe lengths
    2006-08
    Lake Charles, La.
    277
    Default need help calculating pipe lengths
    I have a 3D chassis that we designed for a jeep. I'm looking for some way to calculate the total lengths of the pipe needed to build it w/o having to manually add all the pipe lengths. Would anyone have a lisp routine or any ideas on how I could go about this? I'm attaching a drawing of the chassis. Thanks in advance.
    2003-10
    San Francisco CA
    1,190
    Default Re: need help calculating pipe lengths
    Quote Originally Posted by cwjean76 View Post
    I added property sets using AutoCAD MEP 2008 (AMEP) and did a calculation to determine length (basically volume/area). I assumed that all pipes were the same size. I have included my the drawing with my schedule on it.
    I know you were looking for a way to do it yourself but this was the easiest way for me to do it.
    Hope this helps,
    BTW: Very nice work!
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    2006-08
    Lake Charles, La.
    277
    Quote Originally Posted by stelthorst View Post
    Hope this helps,
    Thank you very much for your help. Yes, I was looking for a way myself, but this suits the need just fine. I do appreciate it however I failed to mention that this design was not complete. It's in the process of still being "tweeked". Would you mind to terribly running it again for us once it is complete?
    2003-10
    San Francisco CA
    1,190
    No problem, Just post the drawing when you're done. Now that I have everything setup it will only take a few seconds to redo it.
    Scott Telthorst
  1. 2011: Pipe-in-pipe, containment pipe, double-wall pipe ?
    By Super T in forum Revit MEP - General
    Last Post: 2019-08-15, 12:51 PM
  2. Pipe Lengths in Mechanical Room
    By ljacobs in forum Revit MEP - General
    Last Post: 2010-05-06, 02:02 PM
  3. Calculating pipe slopes
    By Coolmo in forum AutoCAD Civil 3D - Pipes
    Last Post: 2008-06-15, 12:17 AM
