I have a footing with a pier a blend, an extrusion and another extrusion denoting the grout, leveling plate and base plate.
I had set the visibilty for the extrusions and blend to appear only in fine mode not in coarse. and it works in plan view with the footing by itself and next to a wall footing.
if I cut a section thru these footings and put it in fine my isolated footing looks correct but the footing next to the wall footing "looses" my extrusions (grout, leveling plate & base palte).
does it have to do with the line work or do i need to create additional parameters such as a "yes" "no" parameter.
