Thread: Working with elements in a linked Revit model
    2007-10
    4
    Red face Working with elements in a linked Revit model
    I'm trying to do some interior coordination in a Revit project. I have a structural Revit model linked in, and I am trying to get all the members wrapped with framing and GWB. For vertical and horizontal memebers, its easy enough, but we also have sloping cross-bracing. Is there any good way to get a sheathing wall type to pick the braces as the host and follow their paths?
    2006-01
    4,516
    Default Re: Working with elements in a linked Revit model
    Wall by face, on a mass... But that means you will need a Mass Family in place where the bracing is in the structural model.
    BTW, is it an Accessible condition? We dont wrap the X bracing in sheathing, so much as drop an entire wall around the extents of it down to the ground. Otherwise, someone could miss a piece of bracing at 4' high, with a walking cane, but could slam their head in to it if theyre visually impaired....
    2007-10
    4
    No...its all perimeter. We're just looking to maximize light and space, and want to avoid just dropping walls in front of them.
    2007-10
    4
    Lightbulb Re: Working with elements in a linked Revit model
    Looks like only options are to either re-draft most of the structural model, to have overlayed objects to fix to (masses or reference lines), or I guess to Copy/ Monitor the structure.
  1. Hide Elements in a linked model?
    By mzabritski in forum Revit Architecture - General
    Last Post: 2021-05-14, 09:07 AM
  2. 2014: cannot Select by ID elements in linked model
    By jagostinho in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2014-05-07, 05:12 PM
  3. 2013: Turning off elements in linked file also turns off elements in host model
    By GCIPRIANO in forum Revit MEP - General
    Last Post: 2013-07-21, 11:38 PM
  4. 2011 V/G Filter on Linked Model Elements
    By bwinterscheidt in forum Revit Architecture - General
    Last Post: 2012-12-20, 09:13 PM
  5. Revit MEP elements (wall outlet) hosted by a wall from a linked Revit Arch. model (2 diff. offices)
    By boydljohnson in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2011-02-17, 02:53 PM
