Hi ALL,
Does anyone know how to draw 3D eccentric reducer in AutoCAD?
Photo is attached.
Thanks in advance.
Hi ALL,
Photo is attached.
Thanks in advance.
I have attached two drawings to show you how its done, but you basically use the LOFT command.
All you need to do is select the autocad Radius command and enter the radius size you require, then select the edge you wish to radius.
I have attached a file to show you.
I hope this is what you mean.
the chamfer command also works for Chamfered edges.
I offset the original circles by 2mm giving me the inside shape, then I used subtract to give me the final hollow shape.
It worked perfectly well
If you don't need to see the interiors make everything solid. You will get smaller, faster files that way.
