****edit****
Skip to the first reply that is not by me. and read the synopsis here.
I made a column family with nested knee braces, one on each side. The knee braces had a visibility parameter. If a knee brace was invisible and if interfered with any other model object it would break the visibility parameters.
I now need a way to keep the knee braces in the column family but make them exist, or not exist, instead of visible, invisible. Is this possible?
***end edit***
Sorry for the long subject.
I have a timber column family that I've created. It works and flexes nicely.
I put 45 degree knee braces on each side of the timber column. I made these knee braces as a separate generic family with a couple of types for size.
While in the overall column family, I gave the knee braces a shared parameter. I made a category of shared parameter called knee brace visibility, then within that I made Knee Brace Visibility 1, Knee Brace Visibility 2, etc.
I edited the knee brace generic family visibility paramter to look at one of the shared parameters for each knee brace.
I get this column family into my model and I can nicely turn on or off the knee brace as I choose, depending on the beams above.
The problem it has caused is that I can no longer control the visibility of the knee braces by view range. I've tried editing the overall view range and tried putting a plan region around it, and they're always visible unless unchecked in the family properties. This seems odd, because in the column family, the view range still controls whether or not the knee braces show in plan.
Any tips?
Thanks. Yet again.
