Thread: Batch Change X-ref Status
    2003-09
    381
    Default Batch Change X-ref Status
    Hello to All at AUGI:
    I have large numbers of drawings with x-reference files attached to host drawings. Is there a way to change the status of these x-refs form "Attachment" to "Overlay" in a batch mode.
    The only way I know of is to open each drawing individually, change the status, and then save that drawing. It would be great if I could choose all of the files and change their status to overlay in one operation.
    Any direction would be appreciated.
    Regards,
    Vince
    Houston
    7,520
    Exclamation Re: Batch Change X-ref Status
    Quote Originally Posted by vferrara
    Regards,
    Vince
    This thread contains a LISP example to change an xref from attach to overlay. You could use this as a starting point and put this in a loop with ObjectDBX to change a large number of drawings without having to open them.
  1. Change from Primary to Secondary Status
    By smplancic in forum AutoCAD P&ID - General
    Last Post: 2011-12-26, 11:25 PM
  2. Batch Layer change?
    By .chad in forum AutoCAD General
    Last Post: 2010-01-28, 07:52 PM
  3. How to change Co-ordinate Reaout on Status Bar!
    By Cosmic Traveller in forum AutoCAD General
    Last Post: 2008-06-25, 02:32 AM
