Results 1 to 6 of 6
Thread: Script pro
    2006-08
    Minneapolis, MN
    15
    Default Script pro
    I heard about script pro at AU 2008 and have never dealt with it before. How do I get it?
    2008-03
    43
    Default Re: Script pro
    Quote Originally Posted by plarson.118418 View Post
    Here you go:
    http://usa.autodesk.com/adsk/servlet...linkID=9240618
    Eddy Bussiere
    smp engineering
    www.smpeng.com
    2006-08
    Minneapolis, MN
    15
    Thanks for the link for the location of scriptpro.exe. However, this only works with Windows XP. Is there a scriptpro download compatible with Windows Vista?
    Paul
    2006-12
    29
    Hi Paul! How are you!
    2006-08
    Minneapolis, MN
    15
    Thumbs up Re: Script pro
    Mr. ndbrainard,
    Good to see you still frequent the Forums. Obviously, this thread hasn't gone anywhere with getting it for Windows Vista. Looks like it works fine for XP. It would be a great tool though.
    2001-10
    Defragging the internets.
    297
    You can't install ScriptPro on a machine that has ONLY A-MEP. You need to have the standard autocad installed for scriptpro to install. I had a support case with this issue. They confirmed that it will not install with AMEP reguardless of what the documents say that come with the program.
    If you have a standard autocad you can install it, install ScriptPro, uninstall standard autocad (could be the demo version) and then install A-MEP (or not if you allready have it installed). It does install on Vista with no problem.
    Chris
    PS, support was ****!!!
  1. Script Help
    By geoffrey.m.reynolds in forum AutoCAD Customization
    Last Post: 2012-03-20, 10:24 AM
  2. Need a script to (xx)
    By aharris in forum AutoLISP
    Last Post: 2008-08-22, 05:42 AM
  3. script help
    By mark.momper in forum AutoLISP
    Last Post: 2008-02-22, 06:48 PM
