Thread: Can you build this duct auto?
    2004-05
    784
    Default Can you build this duct auto?
    Can I use the auto function to build wye ducts or do they have to be created as a family?
    See images
    2007-06
    Richmond, VA
    23
    Default Re: Can you build this duct auto?
    Complex fittings have to be placed manually, there are several in the new content extension. Be carefull with the elevations all matching before you try and connect it all.
    I could stop if I wanted to sgermano's Avatar
    2007-12
    Las Vegas, NV
    236
    This is a perfect situation for the autoroute function to actually work. Select the 3 ducts to be connected then select autoroute and have multiple options of wye, pair of paints, ect to select from. Maybe this should be added to the wishlist.... It would definitely be a nice time saver while modeling.
    100 Club Beancud's Avatar
    2007-10
    Down Under
    189
    Wink Re: Can you build this duct auto?
    There is a defult family that looks very similar to what you want to achieve. If you want to compress it more just adjust the family parameter length of that defult wye.
    Q: What is a beancurd?
    The angry revit monster!!...Raaaaar!!
  1. Replies: 2
    Last Post: 2012-01-08, 02:04 PM
  2. Duct/Pipe Auto Sizing
    By ryan.e.harold in forum Revit MEP - General
    Last Post: 2010-11-18, 10:48 PM
  3. Debug Build v's Final Build
    By Phillip_Miller in forum Revit - API
    Last Post: 2009-03-15, 01:40 AM
  4. New Build Comments (moved from new build announcement)
    By sfaust in forum Revit Architecture - General
    Last Post: 2007-10-15, 08:38 PM
  5. 2008 CD build vs. download build - the same?
    By christo4robin in forum Revit Architecture - General
    Last Post: 2007-04-19, 08:51 PM
