Results 1 to 7 of 7
Thread: Duct Accessory Problem- Volume Dampers
    2007-06
    Detroit, MI
    20
    Default Duct Accessory Problem- Volume Dampers
    Hi I was wondering if anyone has come across this problem and what the fix is.
    I am having a problem where some of my Volume Dampers are getting placed in the wrong direction. Systems have been set up correctly, connectors are being used correctly (in and out are set up right). The only way I can get the incorrectly placed Volume Dampers to work is to go into the family editor and change the Primary Connection. If I do this the incorrectly placed volume dampers if deleted and replaced will then be able to be placed correctly, but if I replace the previous correct looking Volume Damper it will then place incorrectly.
    attached is a screen shot.
    2007-12
    Las Vegas, NV
    236
    Default Re: Duct Accessory Problem- Volume Dampers
    when you place the damper can you hit space bar to rotate it prior to selecting the duct to place it?
    2003-02
    45
    Hi
    Krylance
    Please View this detail. .Zip
    Dampers no recomended on that.
    lcchvacr
    2003-02
    45
    Talking Re: Duct Accessory Problem- Volume Dampers
    Hi
    Krylance
    lcchvacr
    2007-06
    Detroit, MI
    20
    Quote Originally Posted by sgermano View Post
    No I cannot use the space bar to rotate the object. The object should automatically know which way to rotate becuase of the connectors, one being the direction of IN and the other being an OUT connector. I can set the connectors to Bi-directional but this problem still exists. I have tried placing a control flip into the family but this doesn't work either.
    Quote Originally Posted by lcchvacr View Post
    Hi
    Krylance
    lcchvacr
    We do not use that kinda of a Volume Damper. We use more of this kind of In-line damper.
    2007-12
    Las Vegas, NV
    236
    thats odd. Sounds like something you should send to Autodesk as it may be a bug.
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,513
    Well, if it is bidirectional, and we add the control in the family, the space bar might work.....but it doesn't sound Revit like...it should know the flow and place IN and OUT in the correct spot...
    Quote Originally Posted by krylance View Post
  1. 2015: Revit MEP Duct Design WYE fitting volume split problem
    By razor_tr in forum Revit MEP - General
    Last Post: 2014-07-01, 08:53 AM
  2. 2012: Duct Accessory and Insulation - Electric duct heater
    By tim.winnington205328 in forum Revit MEP - Families
    Last Post: 2012-07-27, 05:48 AM
  3. Duct elbows, louvers, fire dampers showing right
    By shogan.198666 in forum Revit MEP - General
    Last Post: 2012-05-17, 02:50 PM
  4. Volume dampers won't place on all ductwork?
    By vaughndave in forum Revit MEP - General
    Last Post: 2009-10-01, 10:32 PM
  5. Duct Accessory
    By resident777114711 in forum Revit MEP - Wish List
    Last Post: 2007-01-22, 08:25 PM
