Andrew Dobson
This doesnt work, it always creates the topo levels relative to our ground floor no matter where sea level is.
I contacted Autodesk, and they said that this is a known issue and have put it on their wish list.
A work around could be in the template file, make Project Zero (ground floor) at sea level, then when you start a new project, create a new level at the true elevation of the ground floor, way above project zero.
This requires you to know the height above sea level of the building at the beginning of a project, which is a pain.
