Thread: How to convert pdf to dwg in Autodesk Design Review
    2008-12
    Default How to convert pdf to dwg in Autodesk Design Review
    Hello all! I am new to Autodesk Design Review, is there any way to convert pdf to dwg in Autodesk Design Review.
    Thanks....
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: How to convert pdf to dwg in Autodesk Design Review
    Welcome to AUGI.
    To answer your question, probably not. Design Review was not meant to create new drawings.
    Earth
    9,805
    Quote Originally Posted by macareewall View Post
    Thanks....
    Not with Design Review, but there are ways to do it, with varying success depending on how the PDF was created. See: http://cadpanacea.com/node/30
    R.K. McSwain | CAD Panacea |
    2008-03
    383
    Illustrator will do the trick.
  1. Replies: 0
    Last Post: 2015-08-07, 05:33 PM
  2. Autodesk Design Review 2012 Now Available
    By chris.blocher in forum Design Review - General
    Last Post: 2011-03-30, 07:53 PM
  3. IE7 Hotfix: Autodesk Design Review 2007 and Autodesk DWF Viewer 7.0
    By Mike.Perry in forum DWF Viewer - General
    Last Post: 2006-10-28, 04:24 AM
  4. IE7 Hotfix: Autodesk Design Review 2007 and Autodesk DWF Viewer 7.0
    By Mike.Perry in forum Design Review - General
    Last Post: 2006-10-27, 02:45 PM
  5. Autodesk Design Review Tutorials
    Last Post: 2006-09-17, 02:04 PM
