Results 1 to 10 of 15
Thread: First ACA Rendering
    2006-12
    Big "D"
    3,709
    Default First ACA Rendering
    Okay, here's my first ACA rendering. I know there's issues, but it's not half bad for my first attempt. It looks a bit bright, but the time is set at 2:30 PM, so that may have something to do with it. Any comments and solutions would be greatly appreciated.
    Settings used were:
    Global Illumination - Off
    Sun illumination set to 1
    Energy multiplier set to 1
    Final Gather - Auto
    Exposure Type - Auto
    Sky - Sky background and illumination
    The rest I left as default.
    Anything I missed?
    Why is it called common sense when it is so rare?
    RevitForum.org
    2005-07
    2,354
    Default Re: First ACA Rendering
    Looking good You sorted your shadows out then
    Looks a little bright in the foreground, but as I haven't done any Renders since way before even Viz dissapeared and wasn't that great at 'em anyway, I can't critisize too much.
    What is it for though, to present to Clients or something?
    2008-06
    58
    Looks good! I thought you said you couldn't render worth a damn! I have two suggestions....Make the windows a little darker....and lower the horizon. Other than that, it came out really well. Did you use sweeps for the cornices?
    2006-12
    Big "D"
    3,709
    Quote Originally Posted by H'Angus View Post
    I think I need to use a darker concrete material. I need to experiment with the sun intensity also. Maybe .75 or something.
    It's for a client so he can see what his building will look like. I was just printing a 3D PDF. Either that or doing a 3D DWF. Either way, it looked worse. The boss is happy with the one I posted. If it needs to be better for a city presentation, then we will outsource it.
    RevitForum.org
    2006-12
    Big "D"
    3,709
    Quote Originally Posted by rdaynard View Post
    Thanks for the comments!
    I agree with the windows, they look weird. It's supposed to be gray tint, but I need to work on that. I'll mess around with the horizon. Maybe I'll just throw a screening wall behind the building!
    As for the cornices, no sweeps. Even better. They are custom structural members. That way, when the design changes, I can trim and miter them however I need to. Works great! It's super easy to create custom structural shapes. I even have them saved to a tool palette for different shapes. You need to try it.
    Oh, thanks for your help. It made a huge difference.
    RevitForum.org
    2006-12
    Big "D"
    3,709
    Here's an updated rendering. I took 2.40 hours to render, then I realized that the sky was super dark for some reason. It may have been that the date for the previous rendering was June 1, and I realized that the date for this one was September 1. Oh well, I'm not waiting another 3 hours for a lighter sky! I photoshopped it to be a lighter blue. It's not too terribly bad.
    RevitForum.org
    ACA Community Director dkoch's Avatar
    2003-03
    Going for a long walk off a short pier
    1,848
    Keeping in mind that I do no rendering whatsoever, I think that is a great result for a first rendering. You may, however, want to reconsider your choice of plant materials. The small trees flanking the parking appear to be some sort of flowering tree in full bloom, giving me the impression that it is springtime. The trees in the background appear to be well into fall, and just days from dropping their leaves.
    David Koch
    2006-12
    Big "D"
    3,709
    Quote Originally Posted by dkoch View Post
    I noticed the exact same thing while it was rendering, but thought to myself "nobody will notice". I actually placed the wrong trees, they were supposed to be regular, not fall trees. Leave it to David to see that.
    RevitForum.org
    2006-12
    Big "D"
    3,709
    Okay, I just couldn't live with myself and my poor use of trees. Here's the new and improved rendering with:
    1. Corrected trees
    2. Corrected sky
    3. Updated sign
    4. I even added a person for the heck of it.
    Total render time on my laptop: 3 hours 24 minutes.
    Enjoy.
    RevitForum.org
    2005-07
    2,354
    What about the number plates on the cars?
    Looks much better Dan
  1. New Rendering
    By Bill McLees in forum Revit - Rendering
    Last Post: 2010-04-21, 01:12 AM
  2. rendering help
    By comical_wenger in forum 3ds Max - General
    Last Post: 2010-04-08, 06:08 PM
  3. Replies: 4
    Last Post: 2005-10-18, 12:58 PM
  4. Rendering Hangs (was Rendering Issue)
    By cek in forum Revit - Rendering
    Last Post: 2005-06-06, 11:38 PM
