Thread: Adding multiple annotation symbols to families
    2008-12
    13
    Default Adding multiple annotation symbols to families
    can you add more than one annotation symbol to a family file? I am creating A Fire strobe family, I have a strobe and a horn/storbe combination. Is there a way to use two different annotation symbols in the same family file?
    I could stop if I wanted to jlondenberg's Avatar
    2007-03
    460
    Default Re: Adding multiple annotation symbols to families
    Yes, simply link the visibility of each anno to a yes/no parameter in the family, then you can turn them on and off with either family types or instance by instance.
    In the family, select the anno, go to element properties, under graphics there is a row labeled "Visible", at the far right hand side of that row there is a tiny button, click it to link the visibility of the element to your new yes/no parameter.
    Joel Londenberg
    BIM Manager ACH Mechanical
    "The best you can hope for in this life is that your delusions are benign and your compulsions have utility." - Dilbert author Scott Adams
    This is the correct date format!
    2008-12
    13
    Unhappy Re: Adding multiple annotation symbols to families
    Thank you soo much! This revit is a real thron in my side. I can't wait until I'm more efficient but with our company not willing to put out a single $ I am forced to learn via. the web and free tuts
  1. Annotation Symbols
    By harilalmn in forum CAD Standards
    Last Post: 2010-09-16, 12:10 AM
  2. Imported CAD symbols VS Annotation 2D symbols
    By Binu Mathew in forum Revit MEP - General
    Last Post: 2009-12-30, 02:36 PM
  3. Forcing multiple lines of Text in Annotation Symbols
    By luigi in forum Revit Architecture - Tips & Tricks
    Last Post: 2008-10-21, 10:38 AM
  4. Behavior of annotation symbols in other families
    By sven.129574 in forum Revit MEP - Families
    Last Post: 2007-11-07, 09:34 PM
